Cleaned up shop after finishing aft fuselage section.
Used some Klean-Strip "Aircraft Remover" to remove the powdercoat on bearing and block locations on the various control weldments. The bearings slip on nicely, the blocks do not slip on at all. Some honing or reaming will be required to fit those. Put grease on the exposed metal areas to prevent corrosion until the items are fitted.
Cleaned up the tail skid bolt access hole on the right rear of the fuselage and installed a 5/8" nylon plug found at the hardware store.
Finished the clearance of right rear rudder cable exit. Rudder moves to left/right limits with no cable rubs.
Trimmed and finished the vertical stabilizer forward skin to clear the turtledeck.
Started planning for construction of the forward fuselage.
